Upgrade TB or Not?
Anthony05GT
Maryland
No, I woke up to an inch of snow on the ground. I have a long, steep driveway and 295/40/18 summer tires on the stang. I was all ready too. I put the other pulley on and changed the oil Friday night. Now they are calling for a possible huge snowfall Tues/Wed. As soon as I get to JPC I'll post the video and dyno results.
CandyRedGT
Illinois
I'm liking the new FRPP T-body on my car. Have to wait till spring to try it out much though......snowing again here right now........
CandyRedGT
Illinois
We got 5-6" last night/today...more coming Sat/Sunday!!! DAMN i'm ready for spring already!!!
Anthony05GT
Maryland
OK, here's the results of stock TB and L&M 62mm. On the graph, the blue lines are the stock TB and the red lines are the L&M TB. Upgrading the TB on a twin screw also allowed almost 2 more PSI over the stock TB with the same pulleys. 34 hp gain.
This next graph shows the increased boost.
Anthony05GT
Maryland
I did, but we couldn't make it work without doing a ghetto job on the install. Somebody here suggested it was going to be hard to make it work with a whipple and they were correct. I would have had to grind off some material on the compressor housing to get the TPS wiring connector to plug in and the o-ring didn't line up with the adapter plate.
Jim III at JDM was very cool about it and will allow a return. They are a class act over there as far as I'm concerned.
onequicktang
Orion, MI
but with the stock whipple manifold 14psi is about max for its eff range. So no matter how big of a tb you put on after that amount of boost gains will be minimum cause the intake cant flow anymore imho.
Cobra SS
I agree, working on a fix for that
True, but you will still pick up power with a bigger tb.
