URGENT! Need a passenger side cam ASAP!
Greg Hazlett
Stepping on the Pink Bus
Official Vendor
Chesapeake, VA
We pulled the VC off Luke's car yesterday and discovered one of the lobe's has a small scratch on it.....anyone have their stock cams that would be willing to donate/sell the passenger cams?:helpme:
Greg Hazlett
Official Vendor
Chesapeake, VA
We put everything back together yesterday with a couple of new lash adjusters/followers and the tick seems to be coming from the oil pan/tranny area which has us stupmed.
Might be worth it to drop the pan and inspect the rod bearings sometime...
Greg Hazlett
Official Vendor
Chesapeake, VA
If we do that isn't that bad; disconnect the motor from the motor mounts and jack it up a little but the tricky part would be where to jack the engine up since the oil pan is what I usually use.
LAllison20
Chesapeake, VA
Yeah that is my concern too, although I was talking to my dad and he said a bearing would knock and not tick. The also suggested that the throw out bearing might be the culprit. I don't know how though
Wicked One
westchester NY
Still need the cam? I have 2 sets of stock cams. Let me know. Just pay shipping and the cam you need is yours.
Best of luck.
sent from my Damn phone
Wicked One
westchester NY
One set has 12k and the other has 9k. All yours if you want. Shipping should be no more than like $20.
Greg Hazlett
Official Vendor
Chesapeake, VA
Do you think a spring swap is neccessary since the sounds isn't coming from the head?
Wont hurt to add stiffer springs since your boosted, can't hurt.
Coulde be chatter from the pilot bearing/clutch as it wears down, didnt think of that but now that you mention the sound coming from the bottom that could be a possiblity, still stock clutch right?
Wicked One
westchester NY
I don't have stiffer springs. Just the cams. I am shipping them out tomorrow. Hope it helps.
