sounds similar to the setup with the D1SC I bought from Entrenched. I am running a 3.75 pulley but only want 8 psi on the street and am not ready to push more, but if I do. 10 psi will be all I go on the stock bottom end.
aem truboost controller with a PTE PW46 wastegate should work for you. the truboost controller has the benefit of being a vacuum/boost gauge along with being the boost controller. the gauge is pretty darm accurate too( within .05 psi measured) and with this setup it has a safety feature you can setup in case of an overboost situation it falls back to the spring pressure you have in the wastegate.
you will want to go with the manual boost controller method for the truboost controller for the situation you are wanting. you can set up an 'a' and a 'b' setting with the truboost controller. for setting 'a', you should be able to install the red and green springs in the wastegate which is set or 15 psi, with the boost controller though I would set the spring pressure setting to 13 psi and see where it maxes out with boost. don't change the duty cycle from stock (its 10 percent) and that should be close for the 16 psi. you can play around with the spring pressure setting to get your target boost.
for setting b you will have to get a little more creative. I would definately talk with AEM, (the electronics division). but if you aren't gonna run it a lot in race mode with 24 psi. I think you could switch the spring pressure setting in the controller to 21 and see how the boost controller handles it. you will also have to play with the duty cycle also, increasing it in small steps. if you get an oscillation in boost. you have over compensated the settings for the springs installed and will have to dial the settings back. at that point, if it won't adjust with stable boost, you will have to swap out the springs in the waste gate to the the natural, yellow and blue springs, which equal 22.5 psi and adjust the b setting to around 21 to start with and play with it and the duty till it reaches it desired PSI.
a couple good instruction videos for the aem truboost controller are here, watch all four videos :
http://www.youtube.com/watch?v=7fmg9MhyMDo
http://www.youtube.com/watch?v=arIwCFbjHSQ
http://www.youtube.com/watch?v=sWmIhKJmtbU
http://www.youtube.com/watch?v=eZbxK9uPwnU
