FR500GT
Anybody running Recaro Sportsters?
My knees are bruised from the last autox from bracing myself
I think you are doing it wrong...
And they are in! Just in time for some track time tomorrow!
Maybe add some washers for a little lift?
Does anybody have a bit of rake with their aftermarket seats?
I just came back from a short tip (2.5hr drive each way) and the rake started bothering me.
The back is lower than the front and would like to raise the back about 1"?
Any thoughts?
Do you have any updates about this bracket design? When do you think it would be available? I didn't see anything on your website.In the next few days we're installing seats (both COBRA Imola and Suzuka), harness bars and harnesses into two more S197s, so we're reverse engineering the chassis-to-seat brackets in my 2011 GT and making some improvements... then making production fixtures for these so we can make production runs of these exact brackets, like we did on the BMW E36 this week. Why? Because there's a lot more to installing a seat than buying the seat + slider + side brackets.
Also, would mounting both the anti-submarine and lap-belt anchors to the seat bracket really be safe? I don't see much of a problem with the anti-submarine straps, but I'd think you wouldn't want to have the lap belt load go to the seat mounting points since it will be quite significant in a collision. I know the OEM buckle attaches to the seat bracket, but the other two points are located elsewhere. If I'm using wrap-around shoulder belts mounted to a 4-point rollbar, is that a concern?
Thanks.
Ok, I must have misunderstood. Where on the car do they attach?The lap belts on my Vorshlag bracket both mount to the car, not the seat bracket, just fyi.
Cool. I assume you just added eye bolts and reinforcement plates?behind the seat bracket, in the rear footwell
