Whats your winter mod list look like?
o2sys
NY/NJ
Gonna put it on a diet:
Rear seat deletes (already did):
Stock 2010+ rear seats weight a total of 37lbs will all the brackets included but no the seat belts. The delete weight 8lbs total.
Going to relocate the 43lbs optima to the spare tire well.
BMR a-arms
Lighter wheels that are 5lbs lighter at each corner.
Aftermarket seats ie. Corbeau are 27lbs plus 10lbs for the slider/brackets replacing full power driver/passenger seats which are about 60lbs each.
irishpwr46
Official Site Vandal
NYC
hopefully selling the 08.
for the 12, maybe a smaller pulley and boost-a-pump. not likely until i get new oil pump gears though.
most likely gonna change the tail lights and mirrors though.
ChewyR
Got a forged short block built ready to go in
8 rib pulley kit to spin my DOB kit for 16-18 psi
Eaton true trac and 3.55 gears to replace Yukon dura-grip and 3.73 gears.
Probably throw on a off road h-pipe for good measure
Mustang dog
BMR k member
BMR rad support
Steeda UDP
Motion charge deletes.
Steeda clutch line
Steeda jacking rails
Shifter (MGW or Barton) ordered both waiting to compare.
Motive 3:90 gears
New plugs still researching
07 premium GT manual Grabber orange
Norm Peterson
corner barstool sitter
RIP - You will be missed
Winter mods? As little as possible because I have to work outdoors.
14" brakes, FRPP hubs and front control arms, and a few other odds and ends when the weather decides to stay warmed up without precipitation for more than a day at a time. Springtime mods already.
Norm
travelers
Eastern Pa
Mine is just about complete. New McLeod RST Twin disk clutch and clutch line, Termec XL Magnum trans, New alum drive shaft, Eaton True Track, FRPP3:73, Strange axles with C slip eliminator, Alum rear cover.
Now to finish up with the Drive shaft safety loop, FRPP front hubs.
