whipple parts list , gt500 pump setup drivers, whipple pulley ?
sportinawoody
Piedmont area , N.C.
ok i just bought a whipple kit from a theft recovery that got wrecked. most of the stuff is there but some smaller stuff got misplaced. ive got 3 fuel pump drivers. wondering what part numbers is in this kit as far as the drivers go and i guess i could use my stock one for one of the pumps ???also need a detailed parts list for the whipple kit as whipple keeps blowing me off. also it has a 3.25 pulley. what boost should i see with stock setup vs. 127300 cams, l/t's, o/r hpipe , stock motor ?
AbdullaGT500
Little Rock, AR
The 3.25 will get you around 9-10 lbs with those mods. I'm using a 3.125 pulley with comp 127350 cams, lt's and 324 stroker and I'm seeing between 9 and 10 lbs.
StangPower05
"Pony Up"
NY
3.500 pulley my car made exactly 10psi. 3.250 should see between 11-12psi
69Mach1-409
South Jersey
His Cams & LTs should lower that number sense the engine can move air easier.. wouldn't they?
I'm thinking he should be around 10psi with that pulley.
69Mach1-409
South Jersey
Oh, not sure how much it'll help, but he's a pic I had from the Non-IC parts all laid out on the dinning room table.
Link to the install gallery: http://www.fquick.com/garages/viewgallery.php?albumid=17&carid=18208&page=1
AbdullaGT500
Little Rock, AR
With LT's and cams it would be less. Probably closer to 10. Also depends on the climate. When it's cold here, as in 30-40 degrees I see 11 lbs. When it's closer to 60 degrees I see just over 9.
08fordgt
Tampa FL, macdill AFB
anyone know where i might land the harness for the gt500 pump setup ? got the drivers and the hat w/ pumps
It's hard times trying to find the harness by itself. I've been in the same boat for over a month. I have the pumps and the fpdms.
I'm contemplating having light lads build me a custom setup with the two gt500 pumps and a gt hat.
Yeah Im trying to contact them to see if they actaully still have that part after saleen went under.
Stolen 98
Ohio
I bought the harness two months ago. The only thing is you have to use the SALEEN instructions for install not the FRPP instructions as the harness' are different but accomplish the same thing.
sportinawoody
my tuner wants me to buy a mafia just in case when i get it together and bring it in. he's thinking there is a possibility that my factory meter will peg. i got 127300's, stock block and heads, l/t's and o/r h pipe . i figured with the whipple 2.3 w/ 3.25 pulley putting me somewhere around 9 lbs. in the ball bark of 470-480 rwhp on a mustang dyno, should i be pegging my meter at this level ?
