Roadracer350
Not sure why the watts failure would cause a problem at the front? Now if you were at speed and went super gopher off the track mowing grass sideways then yea but at 15?
Would a Watts link, whichever design be worthwhile for a DD?
I hate to interupt but there hasn't been a post here in two weeks or so.
Or should I just make a simple upgrade of the panhard bar?
'Upgrade' presumes that you're expecting some sort of improvement. Exactly what are you looking for that an aftermarket PHB will produce that the OE PHB will not?I may just go with the simple upgrade. Its completely stock so anything would be better.
so you may have to dumb it way down for me.The front is not designed to be rotated at all around the drive train
Could someone explain to me why a watts will ride better and/or handle better on a shitty road than a PHB? IOW, what major effect does a lateral locating device have on ride quality that a person with a completely stock car would say WOW.
Keep in mind that I also do not understand
I wanna know who is selling $650 panhard bars.
The quote about rotating about the drivetrain was badly worded (and based on a flawed idea). At the time I was thinking along these lines:
The rear of the car was free floating side-to-side. When I turned, the rear of the car started bucking from side to side. The drivetrain would have stayed pretty much straight, since the rear axle was still presumably not moving. The idea was that something that in the front of the car that was connected to the drivetrain, that was never intended to be moved in relation to the body, was stressed when the body started bucking about.
However, in retrospect it was a pretty dumb thought because u joint in the driveshaft would keep anything from affecting the front of the car.
As for how the watts link would affect ride quality... The watts link was the only modification I had made to my suspension, and it got rid of the rear end shimmy that would happen when going over large dips. Additionally, when driving over bumpy portions of the road the car feels less harsh. When I first put on the Watts Link it was pretty noticeable. This last weekend I took it off and put back on the PHB, and it feels a lot worse than it did with the Watts.
Maybe the improvement in ride quality is all placebo as I am sure you are implying. But it is a significant change in the geometry, and not just swapping one lateral location device for another.
I believe it's PIIHB.![]()
