Wire Tuck Thread
Foozeh
If I ever do this on my car I would probably just do a wiper fluid delete like this guy did for the fuse box.
onehotpny
Aragon,Ga
First time i've ever seen it mounted in that location. looks interesting .. only problem is I like my wind shield washer fluid reservoir. without it can't clean the wind shield...
W3bb3r04
Slow 3v Member
Clinton, TN
Another problem is that if you had to change a fuse on the side of the road you would have to pull in inner fender and wheel and all that to get to the fusebox.
onehotpny
Aragon,Ga
Do you know what is pictured securing it in place?
looks like some heavy duty string or cord, maybe this picture will help. what I plan on doing when I do mine is make some brackets , drill the holes I need and pop rivet the brackets to the fuse box to secure it under the dash.
2BlownStangs
Tampa, FL
this was an awesome write as everyone has mentioned. I should attempt this since I'm in the middle of the engine swap.
onehotpny
Aragon,Ga
my partial wire tuck is done :victory:, I'll relocate the fuse box and PCM at a later time once I get some Canton tanks to replace the Vortech ones , until then it would be useless to do the relocation as you can't see any wire for all the braided lines and tanks hide it.Now i have to make a bracket to mount my catch can and figure where I'm going to place it..:headscratch:
W3bb3r04
Slow 3v Member
Clinton, TN
Looks good man! Definitely a good start on it!
here's mine. i was too lazy to do a "how to"
Yours was one of the ones that made me want to do this initially! Looks great as always
onehotpny
Aragon,Ga
Well finished up today, made a clamp for the catch can and got everything done,except I'll wait to finish the gauge wire up till after I get the tune done.
onehotpny
Aragon,Ga
Even when I relocate the PCM & fuse box , mine won't be nothing like this ,since the vortech charge cooler and all the braided lines take a good bit of room. I still like how it turned out so far.
Morris County, NJ
Grrr... this thread isn't that old & most of the pictures aren't loading, I just hope its on my end. This is an awesome project, maybe one day when I have a garage I can work on this.
