W3bb3r04
Slow 3v Member
Thanks cam! I went with the moroso on mine with the jegs cables
RJ, I'm guessing this is the cable kit you got from Jegs?
http://www.jegs.com/i/JEGS+Performa...&cagpspn=pla&gclid=CNjg3qbzq7oCFQ-a4AodiQcAOQ
Still looking more into this and collecting information... slowly building some confidence in this project.
I plan to relocate the Fuse box to where the battery is and then the ECU inside the passenger fender.
How much wiring do you think is needed for extending the harnesses and how much of each type of wire is needed? I would be soldering all the connections and then heat shrinking with the insulators to protect them all.
Hopefully when I do this, I'll pin point the culprit that causes the car to stop responding to the FOB when the unlock button is pushed.
