Wot box the 5.0
luillo
Fort Walton Beach, Florida
Does any body have any kind of schematic or instructions t install the WOT BOX in the 2011 5.0??
I see that Evolution Performance has one on their 8 second car.
I called N2MB to ask for instructions and they said they dont have yet but it is possible to install one int the 5.0. That we just have to look for the Cam,Crank and ignition wires to splice in then the rest is the same.
Get a 5.0 wiring diagram and find the wires you need. Or ask evo how they did it...
luillo
that is my plan, but i was curious if some body had something like that. Is not hard to do the job but i dont know if the Crankshaft position sensor wire or the cams wires that connect to the PCM change location which i think so.
luillo
I really dont need the no lift feature but getting ready at the light without having to worry about rpm launch and getting better 60 ft will be sweet...
Yeah i wouldnt risk it I would wait to get the diagram to verify the pin location/wire color. I tried googling to find anything for the 2011 but no luck so far.
luillo
the two red that goes to the ignition are cake but those two that goes to the pcm are the ones to look for. It has to be easy as hell but i dont have info on the 5.0 to verify. It might be like the instructions for the GT500, it is a DOHC we just need location for the pins. If no body does it until i get back from my deployment then i will do it with details and pics.
Ground
Crank Position Sensor wire
Cam Wire
Yeap, i was just looking over the instructions for install on my my 07, not too bad, but def wanna make sure those other connections are on the right pins.
Sweet, I will be installing in the next few days. I dont have a laptop so gonna have to try to adjust the settings right off the box. It comes defualt to auto for no-lift shift from what i read which is fine I will leave it there but I will probably want to plat around with the 2-step rpm.
Maybe the 2011 is sim to the 2010?
luillo
when i called them and ask about it they told me the software and the program is the same.
Fallenauthority
La Plata, MD
You can purchase a cable from n2mb that you can use to power the box in your house so you can program it on your desktop.
Sent from my Droid using Tapatalk
fdjizm
Drag Queen
NY/NJ
Everything is the same as far as the wotbox program (do this when they press this and do that when they press that etc..) just the pinouts are going to be different for the new engine, new ecu new pins, they should get the instructions soon hopefully.
09 Ricky
Kansas City
Not to sound like a jackass......but what is the purpose for a wotbox? I have searched a few times on here and the only thing I can come up with is it designed for people that cant shift or drive there cars? Sorry if it offends someone which I sure it will lol. I have never had a problem ever shifting like a mad man, hell my old lady even power shifts and that is scary as hell lol, but do people really shift that bad to need one?????
luillo
Well, no offense taken. I can prove i can power shift my car, just look at my videos. The WOT BOX is cool man. I didn't used the no lift feature too much when i installed on my 2009 because it kind of confused me, i used the WOT more for the launch feature... Way more easy to just go to the light and push the clutch down and rev the engine then boom!!!!
Just look at the Evo 8 second car with a lot of power to worry about the WOT BOX comes handy...
Its also perfect for turbo cars, maintains full boost during shifts by just cuttting timing and teh 2-step feature lets you build boost at the line.
Sure i have powershifted n/a, but with 600hp and stock trans, theres no way in hell im going to try and powershift that!
fdjizm
Drag Queen
NY/NJ
No offense at all I can drive my car perfectly fine. The wotbox actually spares your tranny the pain of directly power shifting by cutting the power for a split sec so there is no torque in the tranny while you shift.
I know how to power shift but I would much rather extend the life of my tranny by having a wotbox cut my power for me.
Now if it was my track only car I would be powershifting my brains out and care much less if I can drive it home that night.
and it also doubles as a two step/nitrous window switch.
Technology is a beautiful thing, embrace it. :highfive:
GeorgeInNePa
Clarks Summit, PA
This.
09 Ricky
Kansas City
Yea seems like a cool set up, Im really use to my fox body, banging second gear with the tires still in the air some times, I can't afford that split second in the shifts or the front end would be damaged every launch from slamming back down. Now on the other hand my 09 is a turd......I have plenty of time to think about shifts lol. But having a 2 step is the shit....if it acts like one on the drive by wire that in it self would be worth it :highfive:
onebadgsx
Houston, TX
Did anyone figure out the wiring on the 2011's. Anybody having any problems with them. I heard you need an updated software or something
