WTB Lash adjusters, followers and timing chain kitet
05gtowner
So. Cal
Looking to redo the entire valve train on my 05 due to low oil pressure scarring the cam caps and sludge clogging the lash adjusters. Let me know what you have if anything. Thanks
BadPiggy
Hooligan Ahole
Knoxville, TN
Are you looking for new or used?
I have a set of adjusters & followers, used.
I'd think they were worth $75, shipped.
PM if interested.
05gtowner
So. Cal
Since I have yet to pull it apart and see the issue for myself I would probably be fine with lightly used as I do eventually plan on pulling this engine and replacing it with something that has forged rods, pistons, better oil pump, reworked heads and a decent set of N/A cams. The darn thing runs great though, doesn't burn oil, gets decent mileage still and has never given me one problem. It is just this ticking on initial start up related to worn/sticky valve train because the previous owner didn't maintain it properly. So now I am trying to fix it on the cheap while I acquire all the go fast goodies to then pull it and go through it.
