2012Coyote
Fuggit.
I want these so bad, but if I buy them they will be real LMs but I dont know if I want to shell that much money for a wheel that doesnt even properly fit
Do you have Brembo's?
I went with flat black
The problem is, I'm not sure if the footprint will be too wide and stick out past the wheel well and rub when I launch. This video is of last year with the Nitto NT555R 305/35R18, which turn out to be just over 26" tall. You can see how much it squats.
They do look good, but they're going to rub without a doubt.
You think I should switch then?
wow that wheel setup for the rear looks great! have you tried to see if the 16x8 would fit up front?
Any updates on it?
I know right now I'm leaning towards 18's in the same rim. I've ben trying to do the math with various offset calculators based against what I'm currently running. So far, with the 18's (and I have a feeling that the 18's and 20's stick out the same amount), compared to my 19x9.5's +35, which run right up to the edge of the wheel well, the 18x10 +25 will stick out .6"/15.24mm. I'm trying to get in touch with Shark Tails to see if he could actually measure it for me (his mailbox is full).
have you guys tried this site to compare offsets and the relationship to your car? Works well
http://www.rimsntires.com/specs.jsp
