Norm Peterson
corner barstool sitter
I don't think that damper tuning is going to be very productive for fixing midcorner issues, as the car should already be essentially at equilibrium as far as roll and pitch are concerned.
A lowered rear roll center generally needs more rear roll stiffness, and losing the rear bar probably cost more than the additional rear spring rate added. I think you need to work with these items first, which will probably cause some damper re-tuning as a consequence.
Geometry - How difficult would it be to raise the [currently lowered] PHB just a little?
Stiffness - Either a little more rear spring rate or a soft rear sta-bar?
Post #1 says you have a stock rear bar, but that has apparently been removed since. Had you tracked the car with it still on with all the other mods in place?
Norm
Norm
