My issues were just like you described...
When the engine/clutch was cold, I was able to shift fine, not perfectly since I felt slight notchy-ness, but was able to shift. As the car warmed up, the issues would start to get worst, not being able to downshift or get into gear...mostly 1st and 2nd...hard 3rd. If I was stuck in traffic, game over... I was not able to disengage unless I yanked on the shifter. The only way I was able to get around it was to slightly rev the engine until the gear slipped in...
The whole shim story is BS to me!!! Why would you need shims unless there is a manufacturing flaw where they are producing either clutch discs and/or floater plates with varying thicknesses. In my opinion, it should not be needed...shouldn't all flywheels be flat across the friction surface and pressure plate mount edge; especially on a steel version that does not have a bolted friction disc?
Thank you Autoxracer! You have perfectly described what my issue was. Funny thing is that when my clutch was reinstalled with the McLeod flywheel we checked all of the tolerances and they seemed fine, but with heat came the issue of not shifting! I'm so pissed at McLeod right now because they say my old clutch checks out fine! Really. Put it in a car and drive it awhile and then tell me what you find! I think they may have an issue with the pad compound swelling with heat as well.
So far new clutch is okay but I've only drive it a 100 miles.
