gtmiller1001
I think a key take-away here is that these numbers impressed a Hellion dealer when they are actually right inline w/the advertised numbers of the "base kit" (which this clearly is not). So if it's impressive when you make the numbers you're supposed to make what happens in the every day, not so impressive case??
Yes.
How did you get a stock hellion kit with a vband waste gate?
the story is...no mods, stock hellion kit. flat boost curve @ 3lbs, 7lbs, and 9lbs. all pulls taken to 7,000rpm. any other questions?
Yes.
Either I'm not up on the 5.0's and boost numbers or someones off their rocker.
