When adding the reloc kit, do you run a bit more oil in the motor? I ask as some (idk how much) is sitting in the extra lines.
Yes , it will take more oil to fill to the full mark since you added more volume with the lines and such . You still need the same level in the pan.When adding the reloc kit, do you run a bit more oil in the motor? I ask as some (idk how much) is sitting in the extra lines.
I would imagine you would need to make up for the extra lines and the bigger filter.
Just added protection man - I'm running 7k RPM's for 30 minutes at a time on the road course. I've got a lot of dough into this engine and want it to last as long as possible. Filters and oil are cheap compared to rods and bearings.
againstallodds1 said:Get some fuel injection clamps on there. They are under a dollar a piece, for safety. They look better also. U have to remember that it still is pressurized from the oil pressure. U can get fuel injection clamps from napa.
stkjock said:When adding the reloc kit, do you run a bit more oil in the motor? I ask as some (idk how much) is sitting in the extra lines.
kahmann said:The additional oil capacity is one of the advantages of running an additional filter, oil cooler, and/or relocation.
I'm going to give the oil cooler with twin filter setup a shot. I've got everything I think I need on order from Summit. Thanks to the OP for the thread and to 'Lightblade' again for the input.
I'm using the FL-1-A from the older pushrod 5.0s
So does the FL-1A have the same thread as the FL-820S filter? I bought the same kit you have and I am going out to get some new oil and filter and want to make sure the FL-1A is the right choice.
I want to replace the hoses that come with this kit with something else. Is there a minimum PSI rating that I should be looking for? I am looking at a couple hoses that I have used for other stuff and they are rated 250psi and 350psi. They say they are good for oil.
Are these okay to use?
cool mod , now if someone clever could come up with a remote drain plug so we didnt have to get under the car we would be in business!!! lol x)
