Turbos :) whos running what
KillrStang
Texas Grown
Bryan, Texas
AS the title says list the turbo (with specs) your running and at what rpm you see full boost.
EDIT: What IAT are you seeing and on what IC setup
Im on my last string about wether or not to keep my procharger.
jodadejss06gt
TEAM DELETE SHIT
Severn MD
I'm on an other wise stock powerhouse kit. Came with a 67mm standard bearing, non billet wheel. I have only dumpped the wastegate(rather than return) and also put a qtp cutout on it. My last dyno, I was fully spooled to 9psi at 3200. 5psi at 2700. I love the turbo and a lot of people say how much faster billet wheel turbos spool, but mine is damn fast.
KillrStang
Texas Grown
Bryan, Texas
Yea you cant go wrong with full boost at 3 k that gives you time to catch traction! I love the procharger cause your always accelerating but turbos hit you quick
benjytps
LOUISIANA
Granatelli turbo kit,76mm turbonetics , full boost a 4000 , 9 psi, street car auto , 1.9 60' 11.6 @ 123-125 all stock except turbo kit. no passes yet with the triple disc stall
ctt326
Brenspeed Hater
Fort Wayne, IN
S&H Kit with Comp 67. Last dyno graph showed boost starting to build at 2500 and full boost at 3000rpm.
SteveP
Modular Specialist
Boynton Beach, FL
Hellion turbo kit with Precision 67 billet wheel, precision 38mm wastegate and turbosmart BOV and Go Fast Bits Booston Controller. See boost at 3500rpms and i'm 17lbs on pump gas. Stays all the way up to 7400rpms with no issues. Will re-tune with the Shell URT 115 and bump the boost to 23lbs
KillrStang
Texas Grown
Bryan, Texas
Nasty! are you pre loading your wastegate with your boost controller
michael.konor
Georgetown/Fort Hood, TX
Hellion Turbo Kit; PT 67mm Billet S-Housing, T4 Hot Side Housing, Ball Bearing Option
Turbosmart ProM 50mm Wastegate
Turbosmart eBoost2 Controller
Gutted Cats, and Magnaflow Straight Throughs
Entire hot side wrapped
Boost hits at 3200rpm, 688 Torque at 4200rpm @ 16.2psi, Pump Gas 93 Octane
KillrStang
Texas Grown
Bryan, Texas
Do you break loose when boost hits?
michael.konor
Depends on which set of tires I have on the car at the time.
If I'm on my MT ET Streets, no. If I'm on my Nitto 555's, yes it goes sideways a little depending on street conditions. Once I wear out these 555's, I'm going with the NT-05's on the rear for street.
KillrStang
Texas Grown
Bryan, Texas
Great input guys Really swaying me into wanting to trade my P1 for a turbo. Any good gain by going twin? I believe twins are really for effieciency but seeing yall get boost at 3k not much need for it
ROUSH06GA
MADISON, GA
Precision 6265 Journal Bearing with billet wheel. See full boost 2900 also wastegate dumped to atmosphere. At 10psi made 479hp and 550tq. With restricted mufflers. New number coming near the summer.
JeremyH
3V Fuel Guru
Virginia Beach
On the street with my billet 67 started making boost at 1000rpms and was fully spooled (12psi) by 2000-2200 in 3rd and 4th gear.
If you want a super repsonsive turbo on the street go with a billet wheel, hands down.
retfr8flyr
The Old One
Providence Forge, VA
Modified THP twin kit with Comp Turbo CT3-6062 Triple Ceramic Oil-less Billet turbos. Waste gates plumbed back into the exhaust. Boost controlled by EBoost2 and starts to build about 2300. I see full boost by 2800-3000 in the lower gears and full boost about 2500 in 3rd and 4th. 507 hp and 467 # torque on conservative 15# pump gas street tune. Have run a best of 11.09 at 126 in full street trim.
Earl
KillrStang
Texas Grown
Bryan, Texas
Modified THP twin kit with Comp Turbo CT3-6062 Triple Ceramic Oil-less Billet turbos. Waste gates plumbed back into the exhaust. Boost controlled by EBoost2 and starts to build about 2300,I see full boost by 2800-3000. 507 hp and 467 # torque on conservative 15# pump gas street tune. Have run a best of 11.09 at 126 in full street trim.
Earl
Do you feel like the twin setup was worth it? what advantages over a single turbo do you see
retfr8flyr
The Old One
The advantage in the past, with twins, was faster spool time but with the new Billet wheel turbos there really isn't any advantage to twins anymore until you get into a full race setup with larger engines then ours. When I built mine there weren't any good single kits available. I love the looks of my twin setup but if I were building it now I would just go with a single kit.
Earl
