326 ci Boss block upgrade
JPO8GT
USA
Yes i just have not made it back to Kurgan there yours but i did not want to take your money till i have the cams ready to ship should be within a week.
Jamie
Sent from my DROID4 using Tapatalk 2
JPO8GT
USA
little delay going on right now but all is good... I can still catch up on some rest now that the 4 mo old is starting to sleep all night!! and since my car is not done i wont be tempted to crank it up and piss moma off for waking the lil fela! :sleep:
JPO8GT
USA
Cars running bob will be tuning it this comming week! Things are looking positive will update when done
JPO8GT
USA
:rock:Bob called he's been doing some tunning with the 2.95 pulley at 18 psi he's got the car at 803 RWHP! tommorow they will throw on a 2.75 pulley and see the results..
things are going really good!! Thanks KURGAN!
Bob_Kurgan
this is on c16 with only 20deg of timing.. with 4psi more, im expecting 850rwhp :)
KITT
Sell it!
JC TN
May I ask how much timing your willing to add and feel secure on 116?
What cams did ya go with JP08GT? I have the 127450s. Did you not like them?
Hawgman
THE fucking bad guy
What are the SAE numbers? Not shitting on the results or anything because that is mad power. But SDT numbers are kind of deceiving. Hell, the day I had mine on the dyno there was a pretty significant difference (like 50+ hp) between the STD and SAE numbers because of the temperature, humidity, DA factors, etc.
05stroker
Never enough power guy!
Bullard Tx.
4psi and raise that timing to about 23* and you will have a monster on your hands.
What was the max timing tested at this level? I know sometimes tuners will bump it up and then back it down some before they give it to you. Not all but, some do.
Doug M
Fast Cars & Freedom
AL. Baby
wow man!! congrats and good luck trying to hold on to that bad boy, should be fun..wooo hooo..
Bob_Kurgan
i did custom KMS Stage 4 cams for Jamie's car... as far as timing, ill read the plugs and see what they say..
it made 793rwhp SAE... it actually made 808rwhp STD, but the tach signal dropped at 6500 and it didnt pick up the HP.. but, if i switch to MPH, it obviously picks up the power
JPO8GT
USA
With 80lb injectors, big cams drives like stock until wot i cant ask for more.
BOB did a real good job tunning the 80lb injectors the car starts like normal just turn the key and it fires right up even on cold starts.
this car is alot of Fun and really quick thanks Kurgan!
