Diabolical!
Zapp Rowsdower
- Joined
- Mar 26, 2008
- Posts
- 364
- Reaction score
- 0
You have to run a Metco LCA with their Relo Brackets.
I run UPR's rod end LCAs with Metco's relo brackets. I just had to machine 5/16" off of all 4 rear bushings to make them fit. I'm not knocking any other manufacturer's relo brackets (hell, I've got suspension components from just about every major name in the business), but Metco's relo brackets are excellent. The way they fit up and around the axle tube makes them rock solid with absolutely no need for welding. I really wanted an LCA with absolutely no give in the bushings, so I found a way to modify the UPR pieces to make them fit. (Excellent LCAs, by the way.) As for welding the axle tubes, Kelley is absolutely right. It's the best way to keep your axles where they belong. I had it done while I was getting the tabs for the BMR extreme antiroll welded in and it was worth it for the peace of mind alone.
