Built Coyote Block / JPC Heads for sale
beefcake
Forced Induction Specialist
Official Vendor
Bethel, Ohio
SOLD!!!!!!
Up for sale is our built shortblock, JPC Stage 1 heads, and jpc cam regrinds from last year. $7000
In August, we put together a new block with our forged internals from the previous block.
BES Racing Engines put this together late August / 2012. It was one of the few remaining new 2011 Blocks out there with the larger head stud size.
New Block @ .10 over. All new bearings.
The piston are diamond 9.5:1
Manley H Beam Rods. ARP Head Studs and Main Studs. Cometic Gaskets. Double Keyed.
The heads are JPC Stage 1's. I also added livernois springs to the heads.
The block comes with the shortblock done, heads are still bolted to the shortblock. The cams are in as well. The heads do not have the rocker / rocker arms, and you would need to re use all of your timing equipment as well.
I also have the double keyed ati 8 rib balancer (would work fine for a 6 rib setup) I could inlclude for another $350.
The block has 13 or so passes on it. This setup gave us a 9.03 @ 154.55
Beef
513-478-1965
beefcake
Official Vendor
Bethel, Ohio
we could also install this engine for you as well if you wanted to make the trip to cincinnati
Loudmouth1o
Coral springs, fl
If you split the heads let me know, car was wrecked on Friday but shouldn't be totaled and would really like a nice set of heads to make me feel better.
DTony
Ohio
What are the reground cam's comparable to, something like a Comp stage 1 or 2? And are they a blower grind?
Mystickeith50
South Jersey
Beef...stupid question, but when u say that are you saying you will just throw that in or am I reading to much into your generosity? lol
beefcake
Official Vendor
Bethel, Ohio
willing to use / take as partial trade for an enclosed 24-28 ft trailer / would consider a 32.
beefcake
Official Vendor
Bethel, Ohio
i can bring with me to bradenton or stop along the way as well
2005mach1
michigan
"I also have the double keyed ati 8 rib balancer (would work fine for a 6 rib setup) I could inlclude for another $350."
What Diameter is this balancer? would you sell seprate?
beefcake
Official Vendor
Bethel, Ohio
oem diameter, i won't sell til the engine is sold though
beefcake
Official Vendor
Bethel, Ohio
heading to fl wed afternoon, i can load this thing up.....
beefcake
Official Vendor
Bethel, Ohio
what would you sell the shortblock for if you were to sell the heads/cams seperate
what he said ^^
Okay, heres what I'll do.
Entire engine with the balancer for $6250.
Heads by themselves for $2750
Shortblock / balancer for $3850
Yes, they are blower specific, we did a test on the heads and cams at low boost / timing levels with the stock intake, to give an idea on a mild application how they perform, they performed very well,
with a few more degrees of timing, power jumped into the low 7's
this was without the boss intake, with the boss intake, they get even better
