SOLD!!!!!!
Up for sale is our built shortblock, JPC Stage 1 heads, and jpc cam regrinds from last year. $7000
In August, we put together a new block with our forged internals from the previous block.
BES Racing Engines put this together late August / 2012. It was one of the few remaining new 2011 Blocks out there with the larger head stud size.
New Block @ .10 over. All new bearings.
The piston are diamond 9.5:1
Manley H Beam Rods. ARP Head Studs and Main Studs. Cometic Gaskets. Double Keyed.
The heads are JPC Stage 1's. I also added livernois springs to the heads.
The block comes with the shortblock done, heads are still bolted to the shortblock. The cams are in as well. The heads do not have the rocker / rocker arms, and you would need to re use all of your timing equipment as well.
I also have the double keyed ati 8 rib balancer (would work fine for a 6 rib setup) I could inlclude for another $350.
The block has 13 or so passes on it. This setup gave us a 9.03 @ 154.55
Beef
513-478-1965
Beef
513-478-1965
