Odyssey PC680 battery
Nuclear
Indianapolis, IN
Looking for some feedback from guys using an Odyssey PC680 battery. I have one in my low-tech/carbureted kit car (408cid/10.5:1 compression ratio), and it's been great for six full years now. Of course, that car has very few electrical loads, and draws absolutely zero current when shut off. A modern Mustang is a different story electrically speaking...
I'd like to replace the full size NAPA battery in my '06 GT with the PC680 to save weight. Good idea? Bad idea? Discuss.....
well wrong terminals on it
light weight batteries have been discussed and used on the board by many members - most with good results.
you'll have to fab up a bracket or box to hold it in place.
Greg Hazlett
Stepping on the Pink Bus
Official Vendor
Chesapeake, VA
I used one for 2-3 years with no issues until I upgraded my fuel pumps and found out the hard way how vital a battery with the correct amperage is; I was at the track and could not get a clean run in, car was not going WOT/TB blade open fully and it drove us nuts..it was not until the car was being driven back from the track and the car would start load shedding every 3-5 mins that we figured out though the battery read fine and would start the car with no issues it was not providing the neccessar amps to keep with with the upgraded fuel pumps.
So...if you have a bolt on car/even a FI with a BAP you will be fine, once you upgrade to twin 405 pumps you will have an issue....
kevinatfms
EX-ford tech(6 years)
MD
I don't have the exact listed battery but you can try what I did. I found a battery which fit into a Honda with 400cca at the local NAPA which fit into the stock battery tray perfectly and was half of what my stock battery weighed. ill find the part number when I get home tonight and post.
s8v4o
I had that battery in my car. If it was warm outside it was fine. If it was cold it had issues. Perhaps I had a faulty battery? If I had to do it again I would go with a Braille battery. For the same physical size the Braille is more powerful. Good luck.
custom hold down?
foolio2k4
Buena Park, CA
I use the stock battery tray and drilled a shorter hole in the battery tie down cloth to secure it better.
It does have problems starting up when it dips below 50-60 degrees or so. Warm weather climates should fare better. Im in So Cal and it can have trouble starting up in the mornings.
Takes a few seconds of cranking but it does start.
s8v4o
I did the same thing except I only used the factory tie down. I also hit the hole with a soldering iron to keep the hold together and not start to unravel.
Vorshlag-Fair
Official Site Vendor
Official Vendor
Dallas, TX
custom hold down?
Yes. It is all shown step-by-step here: http://vorshlag.smugmug.com/Projects/S197-Mustang-race-battery/
First I removed the stock fiberglass/composite battery tray, then made this "adapter bracket" out of aluminum. This bracket bolted to the factory battery tray mounting holes + added more holes for another bracket...
Then I used this store-bought bracket made for a PC680 (West Coast Batteries HDB 680) and bolted it to the "adapter" bracket I made (above step). This used counter sunk bolts to flush mount the store bought bottom to my adapter bracket...
The adapter bracket I made kind of hung out in space so I made this support stand to bolt to the lower factory mounting hole...
This extra "stand" gave my adapter bracket 3 bolt holes to mount too (it is bolted under the 3rd hole, at the right, in the below pic)...
Then the store-bought bracket bolted in place...
Then the battery went in place....
Then the CNC top bracket bolted to the base assembly....
Viola!
I made this all with a band saw, drill, and a welder. Kind of ghetto but it is rock solid and has withstood years of abuse, plus I didn't have to drill a single hole into the car and it fit with the factory positive and negative cables. I can unbolt all of this and reinstall the stock bits in 5 minutes.
Cheers,
hardly looks ghetto, looks good, well done Terry
