S&H Turbo Kit Build
06stangia
Iowa
So I ordered a S&H Performance Turbo Kit. The Piping got here the other day so I better get to work. Pictures to come.
-Comp Turbo Technology
CT4-6765 - Rated to 950 HP
Description: CT4-6765 Journal Bearing Turbocharger, ported anti-surge compressor cover (4" inlet, 2.5" oulet) with a 67mm Billet Compressor wheel. HE65mm 10 blade high efficiencey Turbine wheel and a .81 T4 undivided 3" V band turbine housing. Comes with a 1 year warranty from comp.
Hotside components: all 304 stainless steel piping with ss flex couplers and vband connections
-All hotside piping is hi-temp coated satin black to increase spool and reduce heat in the engine bay.
-header connecting pipes 2.5"
-turbo up piping 3"
-down pipe 3" with bung for wideband 02
-3" y pipe split to 2.5" to stock over axle pipes
-38mm wastegate with your choice of 6 or 8 psi spring
Coldside components: all 304 stainless steel
-turbo to intercooler 2.5" piping
-50mm bov
-3" thick frount mount air to air intercooler
-intercooler to engine bay 2.5" and 3" piping to throttlebody
-ss t-bolt clamps and 5-ply silicone couplers
-4" intake tube with 4x7" dual cone filter
Air
-PMAS HPX maf sensor and mounting flange welded on standard.
Fuel system
-550hp drop in fuel hat with walbro 405 pump and fuel system wire upgrade kit
-60lb frpp injectors
Misc
-Oil feed and drain kit
-All installtion hardware
-power steering and oil filter relocation kit
-sway bar relocation kit
-Complete color installation instructions
06stangia
Iowa
Cats off that was not easy and I boke one of the studs on the drivers side. Had to drill out both bolts in the exhaust manifold on the drivers side.
06stangia
Iowa
I have no idea where the small u shaped tubing with the red caps goes.
mikeyfitz
Houston, TX
Its super easy man. I could take off and put on one of those kits in like 45 minutes now lol
Weou09
Bham, Alabama
Dont feel bad...I didn't either. Its not in their install photo and I could not find it in the instructions. Looks like you are also missing the second half of the intercooler bracket. It looks like a stretched out Z. I didn't have it either.
