S&H Turbo Kit Build
JoshK
Modder AKA Fuel
Nebraska
The analog cable is a 6 pin firewire cable like you said, not a usb printer cable. The usb printer cable you need to hook the SCT to the computer.
Hiltsy845
Rich, I have a firewire cable if you haven't found one yet. I don't need it anytime soon. Stop by or give me a shout if you need it.
06stangia
Iowa
Does anyone have the instructions for the S&H Walbro pump install they sent me the wrong instructions.
06stangia
Iowa
I got it installed thats Makdaddy. The pump install file only pulled up one page but i got it from some pictures.
06stangia
Iowa
Is it normal for the turbo to be almost hitting this sensor?
JoshK
Modder AKA Fuel
Nebraska
You do not drill the housing for the BOV signal. BOV signal NEEDS to have vac
It sure looks like the bracket is in the right spot. My precision turbo doesn't have that bump on the compressor housing so my clearance isn't that tight. If you loosen all of the compressor housing bolts, you can probably clock it a little more to get some more clearance.
06stangia
Iowa
Checked the directions and looks like the bracket is on backwards. Need to drill and tap it for the BOV. The directions say to T into the line by the fuel rail and run to both BOV and wastegate.
Makdaddy
I am Dysfunctional
South of Chicago
BOV gets fed from vacuum like Josh said
Wastegate gets fed from the compressor side if you drill and tap it
Ill see if i can get u some pics\
Ck link Good info and pics
http://www.s197forum.com/forum/showthread.php?t=90480
