lethe
V4g!n@ #er
Does arp give a value to use with their lube? I'm going to guess it's 100 since both of you used 100. 70 could be the spec for a different kind of lube like moly.
ARP is 100.
I think arp says 90 with their arp lube , arp lube is moly lube. I was thinking 70ft lbs would be closer to a oil torque spec? I dunno, just seems low.
So you did have a build sheet. Good.
The bearings are a little over stock but not much. The piston to bore is tight for Manley 2618 pistons. They generally specify .003-.0035" depending on application. I don't see the ring clearances but I'd bet they are good.
I have a question for you Gerald. Do you let the motor come completely up to temp before driving it? The 2618 pistons expand as they heat which is why the ptb is .0027", to allow for the expansion. Until they expand you will have some blowby. I don't know how much but it could explain your concerns. Everything could be fine with the motor.
Have you checked into whether or not the aftermarket valve covers have an internal splash shield like the stock ones have? How much oil are you adding between oil changes and how long is that in miles?
Then all that vapor will be coating the inside of your engine bay instead of nicely accumulating in the catch can. Well, not all of it. The stuff you smell in the cabin will be in the cabin.
There are sheilds in those pics. Also what looks to be a pcv valve on the drivers side. Oil isn't splashing out if your covers look like those.
That's why I am thinking its vacuum related.
Update:
Just checked the oil separator:
This is 0.25oz of oil that was accumulated in approximately 30 miles of driving; normal driving with one WOT in 3rd and part of 4th to pass.
I'm sure it depends on the motor but mine didn't even accumulate that much over 5000 miles between oil changes. Seems a bit excessive IMO but I have heard of people collecting a ton of oil in those things.
What I would like to know is why?
I am being hopeful and hoping its due to a tight engine with strong vacuum pulling the oil out.
But what could be other reasons? Why do some people get a little and others a lot; is it dependent on the type of mods?
so in 3K miles (1 oil change) that's less than 12 oz.
