2012Coyote
Fuggit.
Is dumping the exhaust under the car going to negatively affect the high speed/low pressure air flow you are looking for by adding the aero?
Nope, it's so I can build the diffuser how I want to.
And it saves weight.
It's less complex and easier to work on.
It won't rattle/knock if its not there either.
I'm digging it. I'm trying to figure out how to put one together around the GT500 Mufflers. That is probably the way to go.
breaks my heart every time I see Alex's car...
Magnum XL with the taller gear setWhat kind of transmission and gearing do you plan on running? I ran the MT82 and 3.73s on a 2011 at the Mojave magnum and hit around 163 at the mile mark and bounced off the hard rev limiter of 7700 rpm at the same time. On another run tried to pull in sixth gear and shifted from 5th to 6th little past the mile marker at around 7400 rpm and the car fell flat on its face.
Very nice vehicle and work GMitch!
I'm curious to know if you ever ran the vehicle with the current Twin Screw using only X 1 heat exchanger up front or if you went straight to equipping the car with X 2 from the get go?
If you ran the car with X 1 in the past do you have any data you could share on what the Intake charge temps were at the time and how they differ now using X 2 of them?
Thanks
Wait did I miss something, Alex sold his car?
Yes he did.
