AutoXRacer
Air fuel at idle and cruise should be 14.7:1 and vary slightly. Bouncing between 13.5 and 15.6 is a big variation. Tip in fueling should start at stoichiometric (14.7:1) and drop down as throttle (load) is applied. How far down will your gauge read? Is 10:1 the lowest it will read, maybe its less...maybe its even 9 or 8:1!? Having a 10:1 AF at tip in will over fuel the engine. Proof is the tops of your pistons. This will wash down the cylinder walls and create ring seal issues. Oil can be pulled back past the rings and up into your intake track when coming off throttle because your seeing so much vacuum at that point, the engine tries to pull oil from any where it can. We think the oil your seeing in the heads is coming from this, after the motor sits when you shut it down it drains into the chamber and sits on the back of the valves and tops of the pistons like you showed in your pictures.
So if this is the case, would it be easier and worthwhile to just replace the injectors, retune, and see if this works instead of taking the motor apart?
I have new injectors on the way.
We torque the ARP studs, if used, to 20 lb/ft then 70 lb/ft in ford sequence.
