tmcolegr
It's All About the Build
What did you use for head bolts? Ive seen cylinder walls disort from over torquing aftermarket head studs. Around 90 lb/ft the walls begin to distort. The ARP torque specs on their studs is 110 lb/ftWe torque the ARP studs, if used, to 20 lb/ft then 70 lb/ft in ford sequence.
JimIII
If the block is final honed with a torque plate in place, cylinder head hardware torqued to the final assembly torque, using the same ARP studs and head gaskets as used during the final assembly process, shouldn't the bores be round when the engine is assembled?
Isn't this the whole reason for using a torque plate and the exact same head gaskets and hardware as used during final engine assembly?
