BLACK-MACHINE
living my 2nd child hood
- Joined
- Jul 18, 2013
- Posts
- 3,255
- Reaction score
- 3
for fucks sake guys, its a trick question------- the tires are not even on the ground, it weighs ZERO.
$1.00I'm going to go 3550. I'm assuming this is without you in it?
These numbers are undoubtedly used for suspension set ups for a more precise balance. If you are a corner carver, these numbers would be very useful. It's something to take advantage of. My '13 would probably be close to these numbers as it has many of the 'options' you have listed. At any rate, a new addition to my list for 'blueprinting' my suspension. Thanks for posting this.
19COBRA93 is the closest without going over.
Man, you guys think these cars weigh WAY more than they actually do. My car is probably one of the heaviest GTs you can get, so most Coyotes are probably in the 35XX range with no weight reduction.
The car weighs 3617 pounds empty. I should have specified, but it has a manual transmission.
Yeah, the front/rear balance is about what I expected. Maybe with a full tubular front suspension, moving the battery back, coil-overs, weight reduction, etc... you MIGHT be able to get close to a 50/50, but it would be tough.
I weighed my 2013 at the track and it was 3450 with a TT setup on it without me in it.
