Edit- Kelly I doubt you guys have built a fixture to measure anything like the above, but I would be curious of what ideas you had about measuring it or the numbers J&M arrived at.
Hmmmm....
Well, I am not so sure why Brand J chose those figures for measurement. 5 degrees does seem somewhat excessive. Nonetheless, I don't blame them. KISS.
Let's put those #'s into perspective, real quick.
If you had say, 5 degrees of body roll - that would equate to roughly 6" of movement along the axle. So, 3" down on the left, 3" up on the right. (or stationary on the left, and up 6" on the right) 7.5 degrees would be about 8"....so, basically burying the tire in one fender, and a 6" gap on the other side.
Now, during that 5 degree (6" of travel) there is no way that the LCA ends will see said 5 degree. As a matter of fact, I don't really think they would see half of it. The pivot of the LCA is not necessarily working
against the articulation of the rear axle, in all phases of the movement. The first few measurements/moments of travel, will be exerted through the pivot points vertically.
As for measuring, we do not have a fixture like that, because we do not need to - really. If someone is concerned about articulation properties, we have plenty of options for them. We have (6) available part #'s for LCAs alone, for the S197. Three of which, measuring resistance during movement is pointless.
Also, something else about that "test". I see mention of the two-piece bushing "only" being 85 durometer. Well, 85 durometer is actually pretty stiff. We use some of the highest durometer bushings out there, at 90 and 95 on some pieces. I can tell you, in your hand....it is hard to differentiate an 85 from 90-95.
Durometer for durometer - I really don't see that poly ball system being much more efficient in terms of articulation.
There is still a substantial amount of material on each side that the sleeve has to work with. The ball seems to just be taking up space, IMO. If those end pieces were the same 85 durometer, then.....I don't think the measurements would have ended up like they did. I could be wrong, but, I am skeptical. The only way I see the poly ball system allowing for much less resistance, is if it is much lower durometer. Like, 65 for example. I guess my point is, I don't see why the poly ball is any more effective, "durometer for durometer".
We have been offering 3-piece bushings for years, and years. We also release our 11+ UCA with a 3-piece bushing. Then, it failed - epically.
Here is our UCA bushing, that failed.
We are firm believers that the best solutions are simply poly/poly.....poly/bearing.....or bearing/bearing.
If someone reaches the point in which a poly bushing isn't the right choice, I don't see why a poly/bearing combo wouldn't be the next logical choice. I've got daily drivers all over the world rolling around on our poly/bearing components.
