T-56 6 speed Saleen transmission kit FOR SALE!!
JimIII@JDM
Saleen T-56 6 Speed transmission (USED) FOR SALE!!!!!SOLD
http://www.saleeninstructions.com/docs/Install Manual/Data/Powertrain/10-8002-C14949A.pdf
Includes:
T-56 Transmission
Bell housing with modular adapter plate
NEW Slave Cylinder (has almost 1,000 miles on it)
Saleen Shifter Assembly w/ Saleen knob!
Trans Cross member w/ mount
Pilot Bushing
1 piece Aluminum driveshaft w/ flange and bolts
Everything necessary for installation!!! I added a link for the directions. Removed from Customers car for T-56 Magnum XL upgrade, has 23,340 miles on the car so that is how many miles are on this transmission. Transmission came out in excellent condition with no issues just wanted to upgrade to a stronger trans with the 2.66 1st ratio as we are making over 600 RWHP with this car now after a new JDM motor and other upgrades. Please contact us at 732-780-0770 if you are interested!
o2sys
Must resist.....
How much installed? It probably wont work with the 10 spline clutch right?!
justinsstang
Also curious what the capabilities of this trans is.
Regular T-56? Is that like a TR6060 or what =P
JimIII@JDM
It's a pontaic GTO production T-56....similar to Viper, 03 Cobra, and Vette T-56 transmissions which are mostly good for 600-700 HP
JimIII@JDM
Thanks, las question. Will mu current clutch and flywheel be used or do i need a new clutch setup?
You will be able to use the current clutch/flywheel setup except you will need a 26 spline clutch disc.
