swflastang05
Back for More
What did you torque the old heads to? ARP had bad torque specs on some of their stuff, at one point calling for 110 or 120 foot lbs which will distort the block. Most reputable builders are using anywhere from 75-90 foot lbs on the 3v head studs.
I torqued all to 33, then 66, then final was 100lb ft. There was a total of three cracked bolt holes that when pressurized result with water steadily flowing into the crank case.
