mach828
Sell your mustang and pick up a turbo diesel this way you can drive it under 2,500 and have plenty of grunt babying the throttle.
No. But I defy you to find anything that made more power (more than let's say 3-5, which you can't feel) under 3000prm's switching to big tube LT's.
LT's will in some cases increase midrange power if they are designed really well. But low end, no.
Considering my first post said I am unable to find a dyno that shows below 2.5k and asked if anyone has experience with that particular exhaust setup, I challenge you instead to find actual proof of either someone who tried them or an actual dyno below 2.5. If I had the proof I wouldn't have needed to post this thread. 3-5 more is something that I cant feel but it is still higher than the stock headers if it stays above at all levels. I could deal with that because as soon as it hits above 3k it would have much more power.
But you're whole purpose of the thread is to achieve low rpm "grunt." It seems like you've kinda made up your mind either way. Be sure to update the thread with your dyno numbers when you get it all put together.
I'm not trying to be combative here. Just trying to demonstrate that what you're looking to do the way you want to do it is cost prohibitive or not going to work.
You are correct, I am looking for more low end grunt than the stock exhaust. If the aftermarket headers give it more low end grunt then I have achieved that. It may not gain as much down low than it will at mid or high rpm range but its still more low end. It may not be as much as I want but it is still better than not gaining any or worse losing some.
If/when I do use that set I will update the thread. Even if it is a year around I will update it so other people can know the results.
I think the point is that you'll spend $2k on exhaust specifically to gain down low and the amount of power you're gaining is so little that it would be akin to taking the car out at night versus during the day. If you're justifying it by saying that you're also getting power across the whole power band, then you should be looking into a larger intercooler or weight reduction.
Stock Yote - 274 ft lb @ 2,000rpm
Stock Yote with LT's/off road X and mufflers - 276ft lb @ 2,000rpm. $1000/ft lb.
Stock Yote with PD blower - 388ft lb @ 2,000rpm. $43.86/ ft lb.
Cool info, where is it from?
Does it say which primary size of LT's and if they have the data with a catted H pipe which help with more low end?
Off of dyno graphs I have on file.
1 7/8 headers, no cats.
Cats don't make torque.
Apples and oranges.^^^^^^
Unreal - Come on man, using your car as an example of how his 550-600hp 302cu in Mustang will run is well.................... stupid.
OP - the car he is talking about is a 1100hp 427cu in Corvette. He has low end torque because that is what happens when you are making 1100hp up top. He also has a huge displacement advantage, which will produce more torque.
I can tell you from experience driving centri Yote cars in the 550-600hp range that you will not see a noticeable seat of the pants improvement in power under 3750rpm. Hell, even the PD blowers are a little "soft" on the Yote when compared to the 3v.
You got your answer. And that answer is PD blower. It is the first, second and third best option to get to your goals.
-Headers will not improve you low end.
-A centri blower will hardly change your low end at all.
Those are the facts.
Why not just post the file?
Was it an X or H.
I read that cats can help with scavenging but hurt higher up.
Wow. You're missing the point entirely. Did you not look at those numbers? It costs 22x MORE per ftlb of TQ with headers and you would still have 112 ftlb of TQ LESS. I can't tell if you're just trying to prove that you can get 1/2HP in the low end to prove a point or if you actually believe that it's a smart decision. If you don't understand intercoolers and spending $2k for 2HP is a good idea to you then I see absolutely no reason to be driving a boosted car.
I don't care about the cost. I have already said.
So because I don't understand fully about something on a car then I shouldn't be driving it boosted?
Not everyone drives their vehicles the same, but everyone loves power when they hit on the gas. A lot of people try to mod their vehicles for their driving styles and if they can get components to do that and add power then good for them even if it costs more and the cost is higher than another way.
My post didn't say the cheapest way.
A Yote with a Centri making 500-600hp will not spin the tires in 2nd gear at 2000rpm.They can make more than enough low end to spin tires just about anywhere.
Not having a basic understanding of how these systems work is what causes people to lose motors, even the almighty Aluminator. As far as cheapest/cost, we're way past that part of the conversation. At this point we're strictly talking about efficiency; cost just also happens to be a factor because we exist on Earth and use currency to as a way to acquire goods.
You're looking for evidence that supports the claim that centri+LTHs will produce an efficient and reasonable comparison to going with a PD blower and that evidence just doesn't exist. For what you're looking for for your car, a PD blower with the CDC shaker fabbed up to the hood is the way to go.
