4r70w
Metallicats
Saint-Hyacinthe,Quebec,Canada
I plan to by a 4r70w,I found one Lentech but the guy don't have the spec.On the plate,we can see.....4r70/STP,serial number and the year of fabrication,it come with a stall 3800.
how can i know if it have transbrake ??? hp rate ???
On the site of lentech,4r70w/STP doesn't exist
TexasBlownV8
Formerly TexasBlownV6
Central Texas
+1.
Find out if the stub shaft was upgraded or anything else upgraded (my lt 4r70 '1000 hp trans' broke the stock stub shaft at under 600 hp.
05stroker
Never enough power guy!
Bullard Tx.
A quick google search says that is a Street Terminator Plus that is rated at 1k. If it has a TB it will have red wire coming from the case towards the bottom but above the pan.
Metallicats
maybe think about a th400 swap! Reason i did cause its cheaper to fix and also cheaper to build! Just a idea!
I have a deal(I think)4000$ (canadian $)for everything I need to do the swap,4r70w (build 2008 but never installed)3800 stall,shifter,ring gear,trans cooler,everything are brand new..........what do you think ?????
roberts
Bonne Terre, Missouri
All up to u man. Reason I didn't do a 4R was cause they are expensive to rebuild if something happens to it
