Eh, even if it weighs 100# still less then most passengers you would have. Weight savings to only becomes an issue based on location and if you actually race competitively. IE rotational mass from wheeled or a flywheel are a bigger deal then sound deading.
What you say is exactly correct IMO.
Think what the real weight of most guys are ???
A heck of a lot more than my 165 Lbs that's for sure.
The Dynamat installed is simply not going to actually have any real world effect period on mine.
Especially driving it 99% on the street on street tires.
The real effect on mine in regards to how quick it is, is traction ............
Terry, what parts were fixed wrt the suspension noise?
John (DBR Performance) found that some of the nuts on the front strut tower were barely tight at all.
The holes they are in are larger so it lets things move around and jar when going over any Rough Cracks, irregular pavement etc you hear a noise from the suspension.
It is now corrected with no parts needed.
John also has repaired the issue with the LED Bulb Blowing for the Line-Lock being engaged.
Turns out the wiring itself under the custom panel was okay.
What was causing the LED Bulb to blow was feed back from the line lock.
He installed a relay so that stopped the feedback coming back to that LED Bulb on the Line-Lock Btn/Switch.
So now it's all ready for me to come get it.
I just got the call from John a few minutes ago it's done.
He is also going to send the rest of the pictures where he did the Dynamat install.
I'll post them later on for those interested.
T.
BTW,
It just started pouring down outside so No-Mustang today guys.
