What Will I Run?
pacettr
PJ Lover
Yukon, OK
Kenneth w/ alot more track time w/ his setup, less weight, and more mods is at 11.6 @ 116mph... Im curious as to what do YOU thing you will run and at what speed?
:popcorneat:
Kenneth has a stock longblock and only a 3.4 pulley + an auto, which (correct me if I'm wrong) will usually et better but lose some mph over a manual...
Previous best was 12.99 @ 108.48. This was on the stock tires with full exhaust, tune, and Spydershaft.
I have added a Supershaker with 3.2 pulley and all the necessary goodies. Will start out on 26/8.5's and a buddy is bringing some 10.5's if (when) I need them.
I am an average driver AT BEST.
The local track is known for poor times (not the best track prep, DA usually in the 1600-2200 range).
I am thinking mid-high 11's at 122-125.
Be gentle. :popcorneat:
:hi:
kenneth
Louisiana
I would guess for MPH around 119-121.
I'm going to the 3.2 pulley soon and I hope to get around that MPH.
Also just to throw this out there I'm running M&H's that are 28" tall with 3:90 gears.
with shorter tires I would trap a little higher.
pacettr
PJ Lover
Yukon, OK
<--------------3.73's on 26's
chad05gt
Lake Charles, La
ok, lets get a good wagering line going
12.00 +150 under/ -150 over
120mph -150 under/ +150 over
:beerchug2:
ROUSH1711
UNDER CONSTRUCTION
DE
:thumb:I think your mid/high 11's at a little over 120 should be spot on:thumb:
I agree.
This would be my guesstimate also pacettr.
Good luck & enjoy :thumb: Just have fun and the
times will follow. I would go straight to the
bigger tires,hope you capture some video :beerchug2:
pacettr
PJ Lover
Yukon, OK
12.09 @ 118.46
3820 lbs with driver
I'll post all the slips later as well as give details of keeping it out of the wall...:thud:
pacettr
PJ Lover
Yukon, OK
I have given some thought as to why it was a bit off (at least from my expectations).
The track always shatters expectations
I am still on the original tune, which is a little fat
The local track is notoriously slow
DA was ~ 2500 ft
No driver mod, although I kew this going in
I think if I had gotten my tune and run in better air, I would have been about where I expected (high 11's @ 121-123)
I'll try to get vids uploaded this weekend...:beerdrink:
Chevykiller - :clap:
pacettr
PJ Lover
Yukon, OK
Gotcha - I thought street tires from the first sentence. Good luck!
My Price Is Right bid is 12.09
I say 113 mph
117ish @ 11.8ish
This is about what a driver mod would have netted from what I can tell.
~11.7-8 @ ~121
I am going with 12.2 @ 116
I say 12.125 @ 115 on dr's on your first day out with that setup
I had a 12.16 @ 117 in there last night
it was a typo...
12.09 @119 - what do I win?...:beerdrink:
:beerdrink:
:beerchug2:
I lost TWO bets...:tdown:
