nonononono, the point is to get closest without going over.
Why the low MPH's?
Alot of 115-118 up in hurr...???
Kenneth w/ alot more track time w/ his setup, less weight, and more mods is at 11.6 @ 116mph... Im curious as to what do YOU thing you will run and at what speed?
Previous best was 12.99 @ 108.48. This was on the stock tires with full exhaust, tune, and Spydershaft.
I have added a Supershaker with 3.2 pulley and all the necessary goodies. Will start out on 26/8.5's and a buddy is bringing some 10.5's if (when) I need them.
I am an average driver AT BEST.
The local track is known for poor times (not the best track prep, DA usually in the 1600-2200 range).
I am thinking mid-high 11's at 122-125.
Be gentle.![]()
I would guess for MPH around 119-121.
I'm going to the 3.2 pulley soon and I hope to get around that MPH.
Also just to throw this out there I'm running M&H's that are 28" tall with 3:90 gears.
with shorter tires I would trap a little higher.
What kind of RWHP are you putting down.
Surely you jest...?
I think your mid/high 11's at a little over 120 should be spot on
Haven't had it on the dyno but judging from a couple of other PJ's JDM has done It "should" be in the 510-540 range...
ok, lets get a good wagering line going
12.00 +150 under/ -150 over
120mph -150 under/ +150 over
12.09 @ 118.46
3820 lbs with driver
I'll post all the slips later as well as give details of keeping it out of the wall...![]()
it was a typo...
12.09 @119 - what do I win?...![]()
Gotcha - I thought street tires from the first sentence. Good luck!
My Price Is Right bid is 12.09
I say 113 mph
This is about what a driver mod would have netted from what I can tell.117ish @ 11.8ish
~11.7-8 @ ~121
I am going with 12.2 @ 116
I had a 12.16 @ 117 in there last nightI say 12.125 @ 115 on dr's on your first day out with that setup
it was a typo...
