Gabe
Whippled Coyote
Got a revised tune installed.
No more stalling!
TRC51
First time for everything I guess.....
redfirepearlgt
Replaced all 5 rear lug studs on passenger side axle after cross threading one Saturday. Loaded the revised tune - added 1.5 degrees of spark advance down low to try to pick up on the 60ft. I'M READY TO GO RACING!
BTW - It appears that thanks to a clearance hole on the bracket that the caliper mounts to one may be able to install the 3.15" ARP lug studs that are NHRA compliant without pulling the rear axle as had to be done on older fox body cars and maybe others. I will be swapping to those soon enough for easier tire swaps and to minimize future cross threading.
Thenorm
Autocrosser
i just checked my oil life monitor, its at 56%.
I'm in an odd position where I am currently on pace to have to buy new tires more frequently than changing my oil. both were last done in April.
however, since I don't commute in it, and autocross a lot, I don't think I'll let the oil go to %100.
bujeezus
Alabama
Put my T shift handle back on (again). I love the OEM Bullit knob because of the weight, but it's just so scuffed up from the previous owner. Drives me crazy every time I look at it. I need to just throw it in the closet instead of keeping it in the damn glove compartment. I've probably swapped them out 5 or 6 times now.
Mach2burnout
05 Redfire GT
Central Louisiana
Old style Hurst t-handle and you'll throw all others out.
Sent from iPhone
Saleen304
Fixed fuel gauge. After a few times on the road course my fuel level never came off the full mark. Swapped a level sensor from an old pump to the passenger side transfer hat and it works!
nyuk98GT
Infrequent poster
Chesterfield, MO
bujeezus:
Metal polish? There's gotta be a way to bring the Bullitt knob back to original condition. And wrap that little thing up in a soft rag before putting it the glove compartment so it doesn't get scuffed up again, lol. :beatup:
Chris
TGR96
el blanco nino
Huntsville, AL
Picked up a new project.
Dadgum James, how many cars do you have??? You don't need another project, you need to fix the Z06! :lol:
I changed the oil in my Stang, and put in some fresh Mobil 1 and unfortunately, my battery died, so I had to get me a new Duralast Gold from Autozone. About $200 in maintenance stuff in one week sucks donkeys nads.
