retfr8flyr
The Old One
Damn that's some real damage done, at least you know it wasn't the tune, I don't see and signs of detonation causing the failure.
that looks indicative of the factory rods getting a micro stress crack and breaking. I honestly think that billet rod just failed because if it was piston failure the piston would look much worse than it does
I don't know. If the block cracked and leaked coolant into the cylinder, the oil film would have failed on that side of the piston leading to its current state.
Here is what I see.
1. I have a spark plug missing the tip
2. Cracked cylinder wall
3. Broken piston
4. Broken rod
5. Bearing in the crank support is bad
Crank looks fine, bearings look good except the affected cylinder.
Piston tops and sides above the rings look good. No burns or metal flakes.
The way the piston was spun in the hole.I feel like the piston was damaged by the rod as well as the crack on the cylinder. If you look at the picture of the other side of the cylinder, you can see were it was starting to crack were the rod was hitting it as well.
So,why did the rod break? I feel like this is were it all started, but I'm no professional by no means.
We are going to send several pictures to a well know engine builder for his assessment of the damage and possibly help with a timeline of the events.
So you think the rod broke and started everything else? It sure looks that way from here.
What's on the build plan besides a new block? Oliver rods?
When you do a job, you really go all out, Billy
Yes the missing tip is from the same cylinder. That,I must be honest is why I am posting about a 6cc piston now instead if a flattop. And I must admit that some have said will make more power then a flattop in a high boost motor. LolIs the missing tip spark plug from the same cylinder as the damage? Could it be from the piston smacking it? The mind boggling thing is those rods should handle 1000rwhp+ all day long barely breaking a sweat, unless maybe it was damaged during a previous engine failure without being noticed, is that possible? There's almost for certain something else that failed that started the chain reaction. It certainly could have been off balance from the front support mandrel like you mentioned, by bad enough to cause that failure, who knows. What about the balancer, nothing appears out of order with that? How many RPM were you spinning it again? Also was the timing chain all in order up front, nothing slipped, etc.? Sorry for all the questions just trying to help troubleshoot,
No way the piston hit it, the head was there first. The plug cannot touch the piston in my motor.
I have also thought of the previous failures and no.
It could very well be from the crank support bearing failure as it is damaged. I will know more after some expert analysis.
Balancer, timing chains etc is all in order. I went through every part during disassembly and the parts I posted are the ones in question.
I have a feeling a piece of debris took out the plug strap, unrelated to the cause of the failure.
I'm trying to stay serious now. Maybe we should move this to tech now, I'm building shit and don't know what to do. Lol
I have a preference of oliver over manley. they look a little smaller but we've always run them in our sbf's and never had issue with them other than wearing the bronze pin bore liners which are replaceable. they are lighter than the manleys also from my recollection. this looks very, very similar to a stock rod failure to me so I'm betting the rod let go but we will see once you have it looked at by a proper surgeon
Your not helping. LolI have oliver in my coyote!
The only way to make me happy is my 3v scaring the shit out of me every time down the track or put it in the floor. And then there is the discussion in the lanes and pits with the guys with the newer Mustangs and GT500s and all out race cars coming to to see why they got out ran.lolMan, I would give a lot of thought to never touching a 3V again.
I'm completely serious. There are other ways to have fun.
