matt texass
- Joined
- Apr 10, 2007
- Posts
- 1,958
- Reaction score
- 4
o la la![]()
Matt, have you thought about taking all the evap. stuff out. People are saying it is worth 36-40 lbs.
o la la![]()
Matt, have you thought about taking all the evap. stuff out. People are saying it is worth 36-40 lbs.![]()
Have you seen these doors?
http://cgi.ebay.com/ebaymotors/SEIB...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Thank you , this is a great write up. I must have missed that in the other post . I will go back and read what I missed. I thought I got all of it. That is a lot of $$$$ for 20 lbs. Does not make sense to do that then for sure.
we had a couple various threads before this one was made into a sticky and sort of combined , but yes that is way too much for 20lbs lol
yep, we had a big discussion about this a few months ago. Some one actually tore their stock door down to the skin and all the weight ended up being the internal door locks, window mech and window... when it got brocken down it was over $2000 to save a puney 20 lbs off the doors skins? I have to look back on my thread but we ended the discussion as a waste of dollars $$$$$$$$$$$![]()
Aaawww c'mon, Matt. Nothing a little Lexan, some screws, and a door latch kit won't cure.![]()
http://www.razorsedgemotorsports.com/chsu.html
they make a front and rear kit which drops 13lbs each
Any who makes this kit? Would you recommend these for a street car that is rarely driven? Also if someone was to get in an accident with these on. Would they cover the damages?
This off-road rear bumper reinforcement is a TIG-welded aluminum replacement for the stock steel unit, and it represents a 13lbs weight reduction...
Only Weighs 3 Lbs Each!!!!!!!
come on guys any new ideas!? lol
Im going to switch to wilwood brakes this winter, the oem front calipers loaded plus the rotor are 30 lbs each side so 60 lbs. If the wilwood's weigh 30lbs for both im game!
Thats not including a back set of brakes
Would it hurt anything to remove the evaporator stuff on a dd. Not quite sure exactly what is does.
