Marble
In my experience going down a pulley size that gives you 2 psi more at your level will work just fine. But I couldn't do this if your bottom end is stock. If you rattle a stock motoryou may only know because you blow it. With a built motor its able to with stand something like that and be ok.
My suggestion is if you want to be faster is remove weight.
Or put in electric water pump on your car. From my understanding it doesn't make the motor work harder, but frees up power. They cost around $300.
