Saleen underdrive pulley installation
Keith carter
So I purchased a set of saleen pulleys for my 07 gt, has anyone here installed them before and What difficulty was it to change the alternator pulley , I know the horsepower is minimal, but for $91. I figured what the hek, I'm an oldie but a newbie at these new hot rods, any help and insight will be greatly appreciated, thank yall
msvela448
Do you have a manual or automatic tranny?
The Saleen underdrive pulleys are straight forward to install, except you have to use an alternator from an automatic car. The manual transmission cars have a one way bearing set up inside the pulley that can't be changed.
Sent from my SM-G965U using Tapatalk
Dino Dino Bambino
I have a red car
Cyprus
I'd recommend the Steeda underdrive pulleys instead. That way you can leave the alternator alone.
Keith carter
Unfortunately I have bought these brand new, I'm just going to use the crank and water pump pulley. Since I have a Manuel transmission, I have 410 gears so the motor is spinning faster than a normal motor would any way, but at the 1st sign of an issue, I'll swap back
msvela448
There won't be any issues... They work great. You just can't use the alternator one.
06 T-RED S/C GT
Carnegie, PA
I have the Saleen VI supercharger on my "06" GT. The S/C kit includes the idler, water pump, and alternator pulleys. For my particular application, I was able to re-use my original OEM alternator as the Saleen S/C kit requires reversing the direction of the alternator along with replacing the stock pulley. I did not have to swap out my alternator for one from an automatic car. As previously mentioned, the manual cars have a one-way clutch setup integrated into the pulley. Therefore you just change out the pulley by either using a 1/2 ratchet with 17mm hex socket for holding the shaft in place while removing the nut with a 22mm wrench or can also be removed with an impact wrench.
06 T-RED S/C GT
Carnegie, PA
Yes, the alternator pulley can be used. The Saleen VI supercharger kit reuses the original OEM alternator. Only the pulley is replaced, therefore replacing the alternator is not required by Saleen!
Keith carter
My alternator doesn't have a nut holding it on, It looks like a spire with 46 sides ,lol I'll post a picture tomorrow , Guys, thank you, I love this old car, dont want to damage it, ❤
msvela448
Saleen supercharged cars used the alternators from automatic transmission cars... The pulley for that alternator does not have the one way clutch and the shaft diameter is larger. Naturally aspirated manual transmission S197 cars have a different alternator pulley.
The underdrive Saleen alternator pulley will only work with an alternator for an automatic transmission S197 car.
06 T-RED S/C GT
Carnegie, PA
msvela448, I don't know where you're getting info from? But the Saleen VI supercharger upgrade kit does not include nor require replacing the alternator from an automatic car. The Saleen series VI kit included only the water pump, idler and alternator pulleys. The shop that did my S/C installation replaced the alternator pulley with the pulley included with the kit. That being said, I can assure you that my car has the same OEM alternator prior to installing the Saleen VI blower!
What you're referring to is a spline tool. They can be purchased from any auto part stores, such as Advance Auto and O'Reilly stores.
Keith carter
I'm an old fool but a novice at these new hot rods, the last 2 hot rods I had was a 65 mustang 289 and a 76 trans am, been geezer glides since then, over received so much info I dont know what to do, darn, the days of advancing your timing by loosening a bolt and turning the distributor are gone, changing and setting points. now you need a special tool to remove the plugs if they break off, a special tool to hop you car up, and a special tool to take a pulley off, I'm so confused on which way to go, dont have the money on a school bus drivers salary, thank all of you for your help and honesty. KC
msvela448
I'm getting it from my personal ownership of a 2007 Saleen S302SC. And from the numerous articles on problems with the reverse rotation of the alternator when used in a Saleen S/C application. One of the recommended replacement alternators (Motorcraft anyway) is from a 2009 or 2010 Automatic Mustang GT. Those years specifically due to the use of the Denso alternator versus the Motorcraft 6G, and automatic version versus manual due to the one way clutch assembly.
Perhaps your model year of car came with a standard alternator without the clutch, but what the OP is describing kind of sounds to me like the clutch assembly... His picture sure would help... Either way the Saleen (or most other brand's) underdrive alternator pulleys will require a different shaft with a threaded end for a nut.
06 T-RED S/C GT
Carnegie, PA
Perhaps the Saleen S302SC is set up differently from the Saleen series VI S281SC version. I'm also unaware of any related problems concerning the reverse rotation of the alternator when used in a Saleen S/C application. What I can confirm is ever since the Saleen series VI S/C was installed on my car 12 years ago, there have been no related issues/problems with the reverse rotation of the stock alternator whatsoever. I can also confirm that my original Motorcraft alternator has never been replaced in which my car is a 5-speed manual. All that was required was changing the stock alternator pulley over to the alternator pulley that was included with the Saleen VI S/C kit. My car is also a 2006 GT model in which as far as I know did come with the standard alternator. IMHO it would appear as though the Saleen underdrive pulley kits are different compared to the ones made for their S/C kits? But that's just a guess on my part, therefore I really wouldn't know for certain one way or the other. At any rate, when the time finally does come around to replace my original Motorcraft alternator, it will be with the recommended Denso version from 2009-10 Mustang GT with auto trans which has the same pulley size as my current one that was included in the Saleen VI S/C kit. In the meantime, I'll also be very interested in seeing pics of the OP's alternator as I agree that his pictures would indeed help :shrug:
Well, Keith, I don't know if you consider 60 as being an old fart or not, but If you do? then I'm just as much an old geezer as you are :lolsign:
-Rocky
Phil1098
Central Illinois
60!!!! Geeeez you guys are old! At least at 59 I'm not old yet.:whistling: Keith, if it were me I would list that kit in the parts for sale and get a Steeda kit. I couldn't recommend anything higher, really well done and no messing with the alternator at all. BTW, you will come around to the new way of doing things, I much prefer working on mine with sensors, scan tools, tuners, etc. Once you get your mind around what everything does it really is better. Yeah I used to listen for a ping and jump out, turn the distributor a hair and go again until I didn't hear any more knock so the timing was advanced as much as it could be, but now I plug in my tuner which is plugged into my laptop and run data logging software. Make a few runs, email my logs to Lito, he writes the tune based on the logs, emails it back, flash it into the ECM and it runs like a dream from idle to 7,000 rpm.
Keith carter
UPDATE, pulled cold air off, pull radiator fan loosened water pump pulley, changed alternator bolts, put the water pump pulley on it will pot work, sent the wrong one, hit the block on the bottom side, so I put everything back together, and I don't know what to do with them now, boat anchor if I had a boat, then cranked the car and check engine light came on, the intake was leaking so pulled it off again and adjusted, then was ok, oh well could be worse
06 T-RED S/C GT
Carnegie, PA
This is what it looks likeView attachment 69441
Keith, thank you for posting a picture of your alternator. As I mentioned yesterday, my Saleen S/C kit included an alternator pulley removal tool which is basically a socket with a multi-point star fitting that fits the alternator pulley. Using that socket with the impact gun, the pulley came right off. However, after reading over the installation problems you had thanks to Saleen sending you the wrong pulleys, I would follow Phil1098's advice and list the pulleys in the kit for sale or contact Saleen or whomever you purchased them from and find out if they'll provide you with a return authorization to send them back? I also agree with what Phil mentioned in his post that you would be much better off getting your underdrive pulley set from Steeda, this way you won't have to mess around with the alternator at all. In the meantime, we'll continue looking forward to your updates.
-Rocky
Keith carter
Thank you, since I don't know what they are, I refuse to list them, I do have a conscious, I have a bigger plan, cars aren't involved, you see, I'm a big old dummy,just proved it,
msvela448
You might have got a set for an older car. I believe in 2001 the water pump offset was different even though it was also a 4.6L. There was a "long" pump at 87mm , and a "short" pump at 65mm. I think 2001 to 2004 cars used the different pump.
The install instructions for the underdrive pulleys for the 1999 to 2004 Saleen cars is located here:
https://soec.org/literature/manuals/#
NOTE the use of a spacer in the original kit. (Pic below)
You can post them for sale on one of the Saleen forums and someone will probably snatch them up:
https://saleenforums.soec.org/
