So I actually bought this throttle body for really really cheap. I didn't know what brand it was. I'm thinking it's for a gt500 but not 100% sure. What adapter plate do I need? Would this be a direct bolt on with the adapter plate? I got it for really Cheap so if it doesn't work out, I'm not too upset. I'll probably end up selling it
Several companies can sell you the adapter plate – have you tried American Muscle. You will need that part to make the GT500 fit – but it’s easy
What he said was essentially that there are benefits to a larger TB in most situations as long as the air-fuel mapping is correct.
On a N/A 4.6, there's little to gain unless the engine's ability to draw more air at higher rpm is increased by adding higher flowing heads, performance cams, a higher flowing intake manifold, and headers.
Actually you are incorrect. You are on the right track but still not correct when you continue to say only forced induction will benefit. While you hedge by saying the N/A motor has little to gain (acknowledging there is a gain to be had) factually the gain is everywhere but more so at the top end when the engine really needs to increase air flow. Clearly the stock throttle body or even something a bit smaller and anything larger than stock would move (flow) enough air at say 3500 rpm (so half the RPM peak) It’s at the higher RPMs where the engine needs the most air because “RPMs are horsepower and horsepower need air to make it” at 300hp the 4.6 is producing 1.06hp per cubic in. It was not long ago that was considered GREAT. Example a 5.0 Mustang from 88-93 only made .75 hp per c.i.. Then 94-95 it went down to .67hp per c.i. then 96-98 it made .86 and then 99-2004 it made .99. When the first 305 hp Cobras came out everyone freaked out because Ford made 1.08hp per cubic inch with 32 valves. I agree adding higher flowing heads, performance cams, a higher flowing intake manifold, and headers all result in a power increase as well. Side Question – Why would you want any of those things if you still run a stock TB which can barely support the stock HP numbers.
throttle bodies are great for making aftermarket manufacturers tons and tons of money while adding max 15 hp on a blown application
I have a VMP twin 67!
Define tons of money. Speed and HP are never free. Speed can come from dropping weight and that could be free but HP costs money.
Larger throttle bodies did add significant HP gains back in the days when the stock TB's were inadequately sized e.g. single 60mm TB on '87-'95 pushrod 5.0.
Our 4.6 3Vs came with dual 55mm TBs (equivalent to single 78mm) which are already generously sized. Even a stock '11-'17 Coyote 5.0 "only" comes with a single 80mm TB, and that engine has 7.5% more displacement and a 7000rpm capability.
Now you are proving the point. A 88-93 Mustang only made 225 hp. naturally it did not need a bigger TB. AND DON’T FORGET 225 was a wishful HP number. That was SAE with no cats and no accessories drag it down. I owned Paxton back then and we flowed every TB on the market stock good for 400cfm at 15” H20. That sucks. Going to a 65mm TB increased air flow to 435cfm at the same 15” H20. But the trick was the motor only needed 360cfm. And at 360cfm (from the 65mm) the flow restriction dropped to 360cfm at 7” H20. That is where the power came from. The motor did not have to work so hard to suck the air through.
I swapped from oem twin 55mm to FRPP twin 62mm.... on my 2010 auto with M90 ( 5.8 psi boost). I couldn't tell any difference on the butt dyno.....and ditto after VMP re-tuned the entire setup. Boost didn't change either.
What did make a huge difference was the ceramic LT's and hi-flow catted H. Then it all came together. Remove all the restrictions on both intake...and exhaust.... then it all plays nicely. Again, Boost remained constant...@ 5.8 psi.
Or in other words – You are only going to make as much power as the most restrictive part in the flow chain
This is one mod that I'll give a miss. It just isn't worth spending $300+ (Ford Performance version $600+) for a 2-3hp gain.
You just described a 5 cfm increase. What a person does by going to a larger TB is eliminate that part of the restriction. It’s a great add on TO THE REST OF THE STUFF YOU ARE DOING – I don’t think anyone is saying it should be the only thing you do.
Plain and simple FACT. N/A motors and motors that run superchargers that bolt to the center on the engine valley NEED THE LARGEST TB you can run to make the most power possible. PAXTON, Vortech, Procharger and any Turbo don’t rely on the larger TB because they can force it through. For all the guys here that want to do a simple test to prove my point…grab a straw from the drawer or McDonalds, now suck through it as hard as you can. NOW blow through it as hard as you can. You will all see that you can push way more air then you can suck. It’s just that simple.
Agreed....and maybe 5-7 hp gain if a blower is used. The 5-7 hp gain came from JDM engineering... where I bought the FRPP twin 62mm on sale years ago. Most tuners will tell you that a twin 62mm on a NA car will show no improvement on a dyno...or within dyno testing tolerances.
Those guys must all be using dynojets J
Granatelli has to sell throttle bodies so of course they'll say they're good.
On an HCI NA 4.6 there's almost no HP gain from a dual 62mm TB until you hit 5000rpm, and the difference only becomes significant from 6500rpm upwards. Unless the engine has a 7000+rpm capability, or you've built a 323ci stroker (15% more displacement), a larger TB is rather pointless.
Granatelli is here giving free advice. Granatelli looks at it from an engineering standpoint FLOW IS GOOD. And again if anyone here is looking for a power gain below 5000 rpm then Mr. Bambino is correct.
The FRPP twin 62mm is the real deal. Acufab makes both the oem twin 55mm..and also the FRPP twin 62mm.
All the other twin 62mm TB's re-use the guts from the oem twin 55mm tb... like gears / motor/ spring etc.... which is why they cost less. You re-use parts from your oem twin 55m.... rendering the 55mm tb useless. Then they have you tweak the TPS to read the same as oem.
Not true. Accufab never made the stock cast TB for Ford. Also Granatelli does not make you move any guts from stock to modified – it comes complete.
Your factory throttle body is all you need NA. I had a 385 rwhp NA motor and it made absolutely NO difference putting a 62 mm throttle body on it. And by the way the ford racing intake lost horsepower and torque throughout the curve until 6700 rpm where it matched the factory setup with delete plates. All that Throttle body and Ford racing intake is only beneficial if you have forced induction
What other mods – like exhaust, no cats, etc?
Even then, that only applies to a turbo or centrifugal supercharger set up.
You have that dead backwards.
I could tell you that we build 500hp N/A Coyotes all the time. We have made as much as 550. Today 700hp Coyotes are the norm at 9psi - change the TB and its 735 – RIGHT NOW.
Let’s talk Chevy just for a moment a 427c.i. motor with a 12psi whipple makes 900 with the stock TB. Now just go to a 102mm and they gain darn near 80hp. So that proves my point and Dino’s point. HP is airflow dependent.
To answer the 1st question again – check for vac leaks, check TPS angle and get a tune…after you purchase the adapter plate J
