6R80 in my 05
05stroker
Never enough power guy!
Bullard Tx.
I run mine together, I had a momentary switch on the dash until yesterday. I swapped it out for a regular toggle switch to arm it and now use the off button on my cruise control on the steering wheel
daviswarner192
@05stroker I haven't read any absolute confirmation about the stock 4.6 3v flywheel working with the swap. It sounds like it does but there is clearance issues. Do you happen to remember which flywheel you used for your sons car? Or is a stock flywheel would work? I have a circle d 3b 258mm converter as well.
05stroker
Bullard Tx.
His car has an SFI flexplate on it but it is a 3v flexplate.
sportinawoody
Piedmont area , N.C.
i have an extra sfi as i thought they were different and ordered one for a coyote, i was disappointed when comparing to find out they were both identical in every way including height. my extra is an 8 bolt though if you need it
daviswarner192
Thanks for the offer, sticking with the 6 bolt crank for now. Down the road when i rebuild the motor I'll probably go with a 8 bolt.
05stroker
Bullard Tx.
Send me some pictures and pricing on that please I'm about to be in search of a new one
TzReddy
Florida
Has anyone who upgraded their clutches to exedy friction and steels have issue with all of them not fitting per the exedy instructions? The a hub and c hub I had to use 1 less to be able to get snap ring on and have right clearance.
05stroker
Bullard Tx.
I have them but I did not install them
JEWC_Motorsports
S197 Junkie
My first set wasn't the right thickness but the 2nd set went in as instructed. Did you happen to measure the friction and steels?
http://latemodel.cachefly.net/downloads/instructions/EXD-EFK291HP2.pdf
daviswarner192
Ended up purchasing a Hays 12-070 SFI 6-bolt flexplate, it appears to bolt up to my circle d 258mm converter just fine. In case anyone was interested.
daviswarner192
Got the transmission swap done! Didn't end up having to use any kind of spacers, the converter spacing was good with the sfi flexplate and circle d 3b converter. I did not get the computer completely wired in. Just have tps, tach and brake lamp to wire in. I was told by lito my pcm (2007+) should have a clear tach output, anyone know where that should be?
daviswarner192
Spoke with Lito, he told me pin 25 for a clean tach output. Also spoke with Kevin from us shift regarding the diagram. He referenced me to alldatadiy.com for a specific wiring diagram. Looks like the backup lamp pin is only there for the manual trans (I had an auto car to begin with). I can post the diagrams if anyone is interested
