Jgt58
Hmmmm... What's in the boxes.....
Jgt58
About to put these beauties on....
Yes I know they aren't real brembos. They are s550 brakes
Jgt58
This is fixing to happen also...
Jgt58
What's it take to put those on the s197 chassis?
Two washers , 14" s197 rotors , and stainless steel brake lines ( stock will not fit ) , 2015 mustang GT brake pads. [emoji106]
Oh and wheels with proper offset. ( 2015 GT PP wheels are coming )
MrBhp
They say "brembo" therefore they are. Of course they aren't the 27 piston version from my Shelby.
Jgt58
Forgot about these too.
Gt500 brake Shields
Ford Performance oil seperator
Ngauge with custom tune for boss 302 intake
Custom coyote badges as well
ghunt81
New parts on old junk!
Clarksburg, WV
I'd like to know how the PP wheels fit with those calipers. I test fit those calipers on my car with the 2015 GT non-Brembo wheels that I'm running now and they would have required probably a 1/2" spacer (at least) to clear them. As is even with the S197 brembos they needed about an 8mm spacer.
Jgt58
So I'm not understanding what your saying. Are you saying the wheels won't fit even with 15 PP wheels?
ghunt81
Clarksburg, WV
Well, I don't know. The 2015+ has a much different hub setup on the front in that the hub sticks out almost 3/4" further (relative to the rotor face) than on the S197. I don't know what the size differences are between the 6 piston Brembos and the base 4 piston calipers, but on my car when I test fit the 19" GT "premium" wheels I have now (which were not offered with the Brembos) with the 4 piston base calipers they would not clear without a large spacer. So that's why I'm curious to see if the Performance Pack wheels will clear without a spacer or not. Those 4 piston calipers are enormous.
Jgt58
How do you think actual braking performance is on them? Do you know of anyone that has done the swap? And did brembo make them , because they have Ford casting numbers on them.
ghunt81
Clarksburg, WV
Don't know- all four pistons in the S550 caliper are as as big as or bigger than the larger piston in the S197 Brembo so I'd say it's probably pretty good. I swear I thought there was someone here that had done the swap but I don't really remember. And I think I heard a rumor that Brembo made them but I don't remember for sure. I was looking into this stuff around 2 years ago so I forgot a few things.
Jgt58
I'll let you know when I get mine installed
Riptide
Will work for Mustang.
Montucky
Car has been sitting. A lot. Weather hasn't been that great, and beyond going for a cruise, not much else to do at the moment for obvious reasons.
