1950StangJump$
- Joined
- Apr 1, 2010
- Posts
- 968
- Reaction score
- 108
Couldn't find this in a search.
I'm installing an MMR oil filter relocation kit. It eliminates the OEM Oil filter adapter that is on the block . . . and which houses the OEM oil pressure sensor. Contrary to its advertisement, the MMR relocation kit does not have a spot for a 1/4" NPT, which is required for the OEM sensor.
I have a Prosport pressure gauge via 1/8" NPT sender that serves my purpose, so I don't need the factor oil gauge to be functional. But, I don't want the factory gauge to sit on zero and be lit up because it thinks there is no pressure. Do I simply ground the wire that was going to the OEM sensor to make it read pressure, or does it need to see a particular value via a resistor?
