MrAwesome987
I like the white Mach1 that someone posted above. Although I still prefer the 2015-2017 head lights over the current ones.
Imagine how many of those would have sold.
It's also getting the coolers for the differential and transmission.I don't see the demand for these being that good.
Lot of money for a sticker package, a couple bolt-ons. The transmission is the only somewhat desireable part but it is a step down in power handling from the TR6060.
As I said, it is a pretty small market.It's also getting the coolers for the differential and transmission.
Certainly desirable parts for some buyers . . . like the ones it's intended for.
Exactly! I've posted previously I put my 2018 PP1 auto into limp mode at Road America in 12 minutes on track. For those who like to do their "spirited" driving on curvy mountain roads it does not take long at all for the 10 speed trans to overheat. Within a couple laps on track it was struggling shifting.Two or three laps to overtemperature on the track means that there isn't as much margin against overtemperature on the street as there probably should be. And I'm going to assume that nobody who buys a Mach 1 is always going to drive it gently.
I like it because it has a good transmission. I really hate the chinese wonder in standard GT's.
Transmission torque ratings aren't as simple as needing to at least match the flywheel torque number. Seems vehicle weight and the first gear reduction ratio can also be involved.Shifts good but is fragile. Don't even think about a power adder with a TR3160. Why put a transmission that is only rated for 405 lb-ft behind an engine that makes 420 lb-ft?
Even a casual track day guy can overheat a GT's differential fluid. That hardly qualifies as a 'nice solution' no matter whose it was. Never mind that "casual" track day drivers are apt to become at least semi-serious track day drivers.who is road racing GT's? Nobody without money to upgrade - see vorschlag and their endeavors
I think the GT's are perfect for what they do (poking the gas down on the boulevard) and this car is a nice out of the box solution for the casual open track guy.
Yep, and it started with the 2016 GT350, have not heard what is happening with that lawsuit? You'd think ford would have learned with that and upgraded the PP1 and PP2 cars, all they did was put in a supposed larger radiator that doesn't do shit. They build these car with Track apps and say they are only to be used on track, but the car can't run on track and Ford won't back it up! IMO its the biggest scam Ford ever had!At the very least, the PP2 cars should have been better. They had a lot of the right parts for HPDE but missed the mark on that critical cooling one.
