A 305 on a 11 with ET 52-56 will fit the rear without rubbing.
A 285 on a 10 with ET 42-45 will fit the front without rubbing and no spacers needed.
Forgestars, APEXs and several other brands can be had in those sizes and offsets.
If you're hooked on the Velgens, then you're stuck with what they offer. If you're hooked on Nitto tires, you're limiting yourself since there are many other sticky brands on the market.
Several 18" wheels will fit many big brake kits, including 15" rotor setups on S197 Mustangs and 19s clear by an even larger margin. The design of the wheels barrel and spokes are the determining factor. Typically, if they are designed to clear the GT500 15" brakes, they will also clear most aftermarket brake setups.
Baer's website states the Pro+ brake setup will clear most 18"+ wheel designs.
Baer's website even has templates to determine if a certain wheel will clear the rotor/caliper setup.
thank you for the input. I’m pretty much a newb and trying to learn all I can. I appreciate your input
