06 T-RED S/C GT
Also check your barb connections at the intake manifold and air inlet tube for any oil residue. If both connections are dry? then your good to go.
I did something similar. I used a prefilter material from my aquarium inside the catch can. Works great.Decided to check my driver's side catch can since I installed it some 4000km ago. There was about 40cc of oil in it or roughly 10cc per 1000km. Proof that my $25 Chinese eBay catch can with Scotch Brite scouring pad as a filter medium really does work (no need to spend over $100 to buy one). Much better than having 40cc of oil coating the inside of the intake manifold and the back of the intake valves that's for sure! The CMCVs would have been coated too if I hadn't already deleted them seven years ago.
My engine has 94k miles and the dipstick oil level hardly moves over a 5000 mile oil change interval (full synthetic).
When I did that to a little JLT catch can I still had oil residue migrating through the hoses into the manifold.Decided to check my driver's side catch can since I installed it some 4000km ago. There was about 40cc of oil in it or roughly 10cc per 1000km. Proof that my $25 Chinese eBay catch can with Scotch Brite scouring pad as a filter medium really does work (no need to spend over $100 to buy one). Much better than having 40cc of oil coating the inside of the intake manifold and the back of the intake valves that's for sure! The CMCVs would have been coated too if I hadn't already deleted them seven years ago.
I started out with the JLT catch can and ran across the same issues. The JLT filtering design was horrible, there was no actual meshing nor any type of disk filaments to prevent oil residue from passing through the hoses and into the manifold. The filter design consisted of nothing more than just a small piece of window screen used as a filament.When I did that to a little JLT catch can I still had oil residue migrating through the hoses into the manifold.
I'd love to see more pics if you got'm.Thats not true at all. I'm running 315s on 11s up front and 335s on 12s in the back and they fit inside the fenders.
I'm not a fan of stretched tires with the wheels sticking out but thats a style thing. I'm a fan of performance.
Now this is a tire!!View attachment 77545
That wrap is pretty cool. Where did you get it?Installed a new stock thermostat.
The lower-temp unit started popping P0128 codes toward the end of last year, still happening this spring, decided to say good bye to it.
E3s suck. Its a marketing gimmick. All that extra ground strap does is impede the growth of the fuel burning ball. You want minimal ground strap not a ton extra.
I pulled the ADD W-1 catch can off my car & replaced it w\ another similar type catch can but it uses SS mesh filtering (looks like a Brillo pad) contained inside of a removeable threaded double baffle design on the inlet side of the can to improve oil vapor collection\removal thru the double baffle chamber w\ the dipstick protruding thru the outlet port into the can. I like this setup as now since the dipstick is located in the outlet port, if any oil vapor is getting thru the SS meshed double baffle it can be seen collecting on the upper part of the dipstick along w\ any collected liquid oil level on the lower end. The ADD W-1 catch can I was using prior was using baffling only, which while it did show to be working it also showed that it wasn't perfect & due to the baffling design in it wasn't conducive to adding enough SS mesh to my liking to help improve it so I replaced it.I did something similar. I used a prefilter material from my aquarium inside the catch can. Works great.
So the total cost is now 1 set of E3's, plus 1 set of autolites / brisks.... + 2 X labor. He just lost it right there. Cheaper to use the correct plug the 1st time around.
