Sleepy22_98
I just replace the lower control arms in a 2007 that I recently bought. The car has newer struts, shocks, sway bar links, and tie rods. After taking it for a test ride tonight, I am still hearing clunking from something on the passenger side. Thinking maybe the strut mount. Then I noticed that the piston rod threads with the nut are not in the center of the tower hole and was wondering if something was not installed right by the previous owners mechanic. I do not see any kind of camber adjustment bolts on the strut. You can also see marks in the paint of the tower where the 4 nuts used to sit, so it looks like the nuts are nut in the same spot as they once were. So wondering if the strut isnt sitting correctly and this caused damage to the mount. any ideas?
